Help (Knocking)
After looking at the log files from the dyno runs the injector plus width is a little high I think. I think the injectors might be at limits and might need bigger ones. The car is only pulling 375HP at the rear wheels and 430 at the flywheel. I can’t remember what the limit of the stock 28LBS injectors are good for.
If the injectors are the culprit would the SVO 30# be good?
I attached a copy of the log from one of my runs.
http://users.adelphia.net/~dkarpin/Run1.htm
