HPT VCM Scanner filter on discrete values?
Old Jan 20, 2025 | 07:50 PM
weinerschizel's Avatar
Default HPT VCM Scanner filter on discrete values?
I have a PID for Catalyst Over temp Protection. It's values are On/Off. It would be very helpful if I could filter out COT from my data logs when I tune. I know I can turn it off in the config but I nearly melted down my cats so looking for alternatives.
Additionally, I'm looking to tune my TCC lockup. I want to filter data to when TCC is applied then look at knock. I can go off of TCC > PWM lockup pressure (I set mine to 80% across board). However, would be nice if I could just filter on TCC Applied.
Anybody know how to do filter on discrete values like that in HPT VCM Scanner?
Old Jan 26, 2025 | 11:24 PM
01WS6/tamu's Avatar
not possible tha'ts way deeper coding then anything you see or can adjust on the screen side. Your talking custom way in the background programming.
Old Jan 27, 2025 | 12:22 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
You can setup filters for what he wants and much more in the scanner. It is just using filters on the data you are recording, NOT changing anything in the coding. You just have to figure out what parameters you want to filter and what math you want associated with it. COT, DFCO, fast throttle transitions, and transient corrections are all commonly filtered data for tuning purposes.
edit-- And obviously the parameter you are trying to filter has to be in your list of scanned channels.Expression Filtering
Old Jan 27, 2025 | 10:24 AM
I answered my own question. It appears to be a limitation of the software after further investigation. The Boolean and enumerated PIDs are not accessible when you create filters. It could be programmed if one had access to the source code but HPT is not evolving anymore.
Old Jan 28, 2025 | 12:50 AM
gametech's Avatar
Interesting. I have always filtered values, so I did not even realize ON/OFF flags were missing from the available PIDs.
Old Jan 28, 2025 | 10:30 PM
01WS6/tamu's Avatar
ooooooooo I see in vcm scanner hes asking my bad. I thought you were trying to tune pcm and make it look at different variables for performing xx function. sorry bout that.
Old Jan 28, 2025 | 11:47 PM
gametech's Avatar
He is ahead of both of our answers on this. He is trying to filter a specific flag that is just not available. There are workarounds, but based on his thread on the HPT forums, he is trying to avoid those.
