Howell Engineering LT4 harness not working
Old Jan 31, 2025 | 04:51 PM
calponte's Avatar
Default Howell Engineering LT4 harness not working
Hi guys. Got an issue with a harness I purchased form my LT4 swap.
I called howell engineering and told them what I was building. LT4/4l80e swap into a 56' pickup.
The guy there said no problem, we'll build you a harness and ecu for your application. You'll just need to get a stand alone TCM.
Fast forward to this month. We got everything installed and the engine has about 25% power. Got a tuner involved and he logged into the ECU and said it's in limp mode and it looks like it's due to no VSS sensor signal.
Call Howell and they say " gee..yeah, not really sure what's happening as we've never built one for a SC application". So now i'm paying a couple guys to try and do their R/D to find a work around. Needless to say i'm pissed, I would have never bought this crap if I had known I was the guinea pig.
Anyone ever run across this issue doing this swap. Did you find a VSS work around or figure out how to properly pin in an old 2 wire VSS instead of a 3 wire?
Thanks for any help
Old Feb 3, 2025 | 04:51 PM
minytrker's Avatar
It can be done but highly unlikely your getting it to work with anything from Howell. You'll need $4600ish for a new harness and ecm/tcm setup.
Old Feb 4, 2025 | 05:09 PM
mrvedit's Avatar
Moderator
I looked at the Howell website and it clearly states they have an LT4 harness, which implies it is for SC.
And then they don't?
Write, but don't send yet, a letter to the FTC and the BBB and include them in your communication to Howell, stating you will mail them if they don't quickly refund your money.
Old Feb 4, 2025 | 05:37 PM
calponte's Avatar
I think I will do just that.
This is unreal and should have never had to be done
