MAP trigger output possible from P59 pcm ?
Old Apr 8, 2025 | 03:41 PM
Full Power's Avatar
Default MAP trigger output possible from P59 pcm ?
Is there any possible way to get a MAP thresh-hold triggered output from factory P59 ?
How about KNOCK sensor output ?
I envision a dashboard WARNING light from Knock sensor activity.
I would like to set up a PCM trigger for single stage stone-simple water injection sytem, activated by MAP
Old Apr 10, 2025 | 01:44 AM
LS_caddy's Avatar
You can use the AIR pump output. Set the minimum MAP value to what you want, max MAP value to something high. Set all the RPM disable, timers and such to values that work.
I am not sure how quick it reacts, but this is the only thing I can really think of
There is no way for a knock indicator light
