Back: Hanging Idle and "Cruise Control"
Either way, if you're seeing highly elevated fuel trims during the condition and extreme variations between banks, that's a pretty big indication of unmetered air entering the system somewhere. In my case I don't see those things, which is why I've arrived at the conclusion that mine is a matter of metered air entering that shouldn't be (meaning a fault in the PCM to IAC command signal - hence a high idle with a 0 IAC count and no signs of unmetered air).
So I talked to the guys who did the smoke test, and turns out that they did it when the car was cold. So the next step is for me to get it good and hot, do some WOT runs and hopefully induce the condition, and then do another smoke test. Stay tuned.
I didn't realize how weak the old battery had become until I experienced the difference with the new one. I'm now wondering if the reason this issue had disappeared for so long is that I had, in fact, fixed it with that new EVAP solenoid but then a new issue developed due to either the loose battery cables or just the weak, old battery. All of this occurred to me as I was doing the idle relearn procedure for the new battery, and I realized that, during the procedure, it displayed some of the same odd idling traits - but that it all cleared up once the relearn was complete (even before doing a restart). The '98 PCM seems to be really sensitive to idle relearn/idle parameters (as compared to how my later cars all were), so perhaps an old battery and/or loose connection at the battery post was somehow causing havoc/corrupting learned parameters?
I've only driven the car a couple times with the new battery, but so far all is well. I guess we'll just have to see how things go over this summer, but I'm hopeful that it might have been something this simple because the issue was gone for quite a while (after replacing the EVAP purge solenoid) when the previous battery was still new.
The car immediately started to run normally, until one day last week when it completely FREAKED OUT per my description in the other thread: I'm cruising at about 40mph @ 1600 or so rpm with my foot off the throttle. As approach a stop, i shift into neutral to be able to slow down, and the rpms spike to about 2600, all with my foot off the throttle. As the car comes to rest, the idle slowly settles down to about 900 (setting is at 650).
Since then, it has run normally - no extreme events or semi-normal or moderate behavior - but I'm waiting, and course hoping, that it will have finally settled back down. We did find a bad coil and burned plug wire, though no misfires on that cylinder were detected. The conclusion that I and the techs I've been working with is that it is not a mechanical or vacuum related problem, but that the PCM is seeing something it doesn't like and responding to it.
My next step if the issue recurs is to have the PCM connections and grounds inspected and tested.
So this time I not only disconnected the purge line and capped off the intake nipple, I plugged the purge line and disconnected the solenoid. And it's back to running normally. Opening the gas cap doesn't release any fumes. I'm becoming convinced that the vent valve solenoid gets stuck open, and when the purge solenoid kicks on, it creates a vacuum leak as you have described.
Back in 2016 I had a problem for a couple of months with the gas nozzle shutting off when I tried to fill the tank. My theory was that the vent solenoid was stuck closed. Now I think it gets stuck open at times, and this accounts for the intermittent nature of the problem. Make sense?
FWIW, I've driven mine a couple more times since replacing the battery and doing the relearn, and so far the idle has been rock-solid stable. Not that I think that your issue is the same, but I just wanted to update this for anyone else searching in the future since the topic came back up. I still won't consider mine "solved" until it's gone a whole year without returning though.
...I'm now willing to revisit the possibility that the issue might have been somehow connected to a problem with the battery/battery cables/voltage. I finally replaced the battery (at 10 years old) because it was starting to sound a bit weak on initial cranking. In so doing, I discovered that the battery cables had come pretty loose, likely because the lip on the battery tray was partially broken so the battery was not as secure as it should be. I replaced the whole coolant overflow bottle/battery tray so the battery would stay properly secure, and I reinforced the lip to prevent this from happening again, and installed a new battery.
