1998 Trans am tuning for cam
1998 Pontiac Trans Am
Ls1 w/ texas speed maddmaxx cam
228/232
.550 /.550
110 +5 LSA
862 truck heads milled
10.5:1 compression
texas speed rockers / pushrods
ls7 lifters
stock intake + TB
TR55 plugs gapped at 40
4l60e
2:73 gears
275/40/17 all 4 corners
I hope i posted in the right place and someone can give me some insight. i am by no means any good at this but i plan to get good at it so any help is appreciated!
Either fail the MAF and tune the VE or make it where it runs only on the MAF
That's a lot of BRAF for that engine. Disable idle adaptives, adjust the TB set screw where the IAC counts are around 40 at operating temp.
You will have to redo the BRAF table after that.
Raise idle RPM some until you get the tune closer.
If you are taking to someone to tune it, can you not get a base tune from them?
Not being a dick at all. But I have a pretty good idea of someone skill level based on their questions and what they are logging.
Shoot me a PM
