Very strange P0016 code after engine warms
1. replaced the ECM
2. replaced the crank sensor
replaced the cam sensor
replaced the oil pump to a M295HV
replaced the cam phaser, timing chain crank sprocket and tensioner and cam bolt valve
replaced the VVT solenoid
replaced the TPS
checked all grounds to coils and injectors
Checked fuel pressure
Has spark and fuel
replaced cam sensor (GM)
replaced crank sensor (GM)
When it's running normally, the cam variance will display .500 degrees and is stable but will display maybe 1.9 degrees when revving. The cam variance will also display .500 during cranking followed by a normal start. However, when it quits, it will display 19.3 degrees while cranking and then quickly drop to .500 degrees, sometimes sputter, and then go back up to 19.3 degrees and won't start. Yesterday I ran it until it quit when the oil got to 203F and the oil pressure hit 20. I drained the hot oil and put in cool oil with some Lucas treatment and I got it start after a few times cranking. It ran longer but eventually quit and wouldn't restart until this morning. So it needs oil pressure higher than 20 psi to keep it in time.
When I put the new phaser in, I rotated the engine until the timing marks lined up on the old one. Thinking back, I remember seeing the cam gear on the old phaser turning slightly without moving the cam but I can't remember if I was turning it clockwise or counter clockwise during that. When I installed the new phaser, I'm a 100% sure the marks were lined up and have a photo to verify it.
But it seems that the timing is off when these no start situations happen as verified by the cam variance and it happens when oil pressure is low and oil is hot. From what I understand about the VVT phaser is that it locks at 0 when there is no oil pressure so the timing should not be off, but it apparently is. If the timing marks were lined up during install, then I should be golden. I'm wondering if it was off a tooth and the oil pressure was needed to bring it back in phase, that might explain why it only runs with oil pressure above 20. But on the other hand, how could it be off a tooth if the marks were lined up?
I am completely stumped but I hate giving up. If by any chance it is off and the VVT is adjusting the phaser to bring it back in to time during a cool start, if I disable the VVT in the PCM then it shouldn't start under any condition. In other words, the timing would be off under hot and cold conditions.
If you can follow my rambling, I'd like to hear your thoughts on my logic. Below are the timing marks as installed and the screenshot showing the timing variance between commanded and actual.
I'm going to attempt to scope the cam and crank correlation to see if there is a difference in the timing from a good start and a no start. It should also let me see ow clean the signal is from both sensors. I even tried a second replacement cam sensor (AC Delco) with no change. It still also could be a grounding issue and I could replace the harness to rule that out. They seem cheap enough.
