Cam position sensor low voltage
Old Apr 29, 2025 | 05:41 PM
Kustomom's Avatar
Default Cam position sensor low voltage
I know this has been posted but I’m stuck! I have an LH6 from a 2005 Trailblazer. (I know. Huge mistake!) Did DOD delete & whole nine yards. Put it in my 1990 c1500 truck. I am losing voltage from sensor to ecm. We have replaced the ecm & we’re on our 3rd sensor. We’ve checked &/or jumped the wiring. We’re stumped. HELP!! Intermittent but more often then not problem. When shows normal voltage start runs normal then low voltage pops back.
Old Apr 29, 2025 | 11:32 PM
Guy with a Chevy's Avatar
If your saying that the signal is working intermittently and you have checked the wiring already then I would suggest probing the reference voltage and make sure it's not cutting out. Not much else we can suggest without more info. I will try finding your other post
