Trans Pressure sensor issue
Old May 4, 2025 | 09:10 PM
Novapat67's Avatar
Default Trans Pressure sensor issue
I have a 0-300psi pressure sensor screwed into the port of my 4l80e. It worked fine for a while and recently, I updated the Holley software and changed a few things around. The car was also sitting for a while. Now, it is showing 300 psi all the time, even with the car off.
Any tips on diagnosing what the issue is? I can definitely buy another sensor, but I want to make sure that is the issue. Could I have set it up wrong in the Holley software so that it would show 300 psi? Thanks in advance for any help or advice!
Old May 7, 2025 | 09:06 AM
91 Z28's Avatar
Wiring is wrong. Check the pins on the connector
Attached Thumbnails Trans Pressure sensor issue-gt_150_wiring_diagram_700x.jpg
Old May 8, 2025 | 01:06 PM
Novapat67's Avatar
100%. Just wanted to update. I got the yellow output wire from the 12v-5v converter mixed up with the yellow signal wire from the sensor. Works great now. Thanks for your help!
