Holley pro dash High beam signal
I’ve figured out both turn signals how to display them pulling from the gauge cluster wiring. Same with fuel level but can’t figure out how to have high beams trigger a 12v signal when on. I’ve tried the light green wire from pin A17 (headlight high beam supply voltage) and it flashes when turn signals are on. Doesn’t just turn on and off with high beams only. Any help would be appreciated!
