Logging oil pressure hp tuners
Old Jun 7, 2025 | 06:12 PM
Steves1911's Avatar
Default Logging oil pressure hp tuners
For some reason while data logging im seeing -15.4 psi never varies. Factory gauge on dash is working properly 30psi warmed up and increases with rpm. Im sure its probably something with hp tuners . Brand new gm sending unit if it matters.
Old Jun 7, 2025 | 07:51 PM
LilJayV10's Avatar
You can't log it through the PCM on these cars. I know it will let you select it, but did doesn't actually do anything.
Old Jun 7, 2025 | 08:35 PM
NSFW's Avatar
There's no sensor hooked up to the PCM from the factory. I went through the same disappointment with my C5. The annoying thing is that car has the sensor, but it's only wired to the dash.
Old Jun 7, 2025 | 08:53 PM
Steves1911's Avatar
Well damn. Thanks for the replies .
Old Jun 7, 2025 | 09:02 PM
LilJayV10's Avatar
Since my EGR is deleted, what I ended up doing was add a 5v 0-100psi sensor below the factory OPSU, and logging it through the EGR signal wire like some do with a WB02.
Old Jun 8, 2025 | 01:31 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I have been doing that for fuel pressure.
Old Jun 8, 2025 | 03:17 PM
BReal408's Avatar
So what is the voltage signal I am seeing on OBDXplorer? It goes up with RPM...
