DBW failure
Old Jun 16, 2025 | 08:22 PM
BReal408's Avatar
Default DBW failure
Got a cool new problem. Starts up and idles then after a min idle creeps up to 2100 rpm and my gas pedal stops working. No CEL no codes. Reflash same tune and its back to normal for a test drive then does it again. Anyone been thru this before? I am guess ing it is just going into limp mode but why? No codes to tell me anything..
Old Jun 19, 2025 | 12:49 PM
mrvedit's Avatar
Moderator
You need to tell us what year and vehicle/model this is. Stock setup or mods? Do you know what ECU or pedal this is?
Old Jun 19, 2025 | 04:50 PM
NSFW's Avatar
My only guess is that there's a vacuum leak, and a big one. But diagnosing over the internet is hard.
Data logging would help. AFR, MAF, desired idle air, ignition advance, throttle blade angle, pedal position, RPM... not sure what else, but that will probably do.
Old Jun 20, 2025 | 12:15 PM
Bbknucks's Avatar
Also make sure throttle/pedal related codes aren't disabled in the tune
