No spark cyl. #2 LM7
It would only take one good strand to show good power or ground on a meter or test light but once the current starts flowing it will get eaten up by said bad connection.
To load test I always use a head light bulb cause its bright enough you can tell when the circuit sucks as it will be dim.
So in this case you could use the head lamp bulb across the coil power and ground supply at the connector and see if it lights up bright.
You could also use your meter while a circuit is being used and measure the voltage to see if its dropping correctly at the load source. (Voltage drop test) you would backprobe at the connector the voltage should be battery voltage there. If say its only 7 volts then you know 5 volts or so of power are being eaten up by resistance somewhere. Also on the ground side should be zero volts if there is again say 7 volts there then resistance is on the ground side eating some of the voltage up
I will let you know in a bit.
