Turbo 5.3
Old Feb 7, 2026 | 03:39 PM
corey877's Avatar
Default Turbo 5.3
Anyone have a tune file they can share for tuner pro have a 5.3 with stage 2 cam 80lbs injectors dbc 78mm turbo 92mm throttle body th400 non electronic trans want to run on pump gas no one around me will tune it they won't tune older ls motors
Old Feb 8, 2026 | 12:49 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Although it would be nowhere near ideal, you can get away with someone else's generic tune file on an NA motor. On a turbo motor, you will just end up with a trashed motor that runs bad before it blows. You need real tuning. There is no other legit option. You either find a tuner, learn to do it yourself, or own an expensive paperweight.
Old Feb 9, 2026 | 05:45 AM
corey877's Avatar
if i can find a file I can at least compare to just to get me started so I can data log and adjust from there so I dont hurt it
Old Feb 9, 2026 | 06:31 AM
Tommy42088's Avatar
Get a remote tune.
Old Feb 9, 2026 | 05:19 PM
gametech's Avatar
If you post your .bin, there is a tiny chance somebody that knows what they are doing may be willing to modify a good starter file for you, but you would have to provide exact part numbers for the injectors, exact cam specs, full description of your fuel system, part number from your MAP sensor, etc., in order for that to happen. Comparing to someone else's modified file is a recipe for disaster. If you know enough to even know what to look for you would not need their file in the first place.
