PCM not commanding TCC lockup
I am able to trigger the PWM TCC solenoid as well as other solenoids both manually providing ground and power at the correct contacts on the trans harness, as well as through an Autel scan tool from OBDII port.
I segment swapped the transmission diagnostic and calibration tunes 4L80e tune from another 2007 express 3500 van with 4L80e, and still no change using Universal Patcher.
Is there anything else I should be looking at in the tune to get the computer to command TCC lockup?
https://www.psiconversion.com/produc.../KIT-1002.html
Rick
I cannot figure out why the TCC is not locking up.
