New datalog analyzer for Terminator/Dominator logs
I asked a question on FB regarding this, but didn't get a response. Explain, in simple terms, what this actually does for someone that merely reading a datalog would not. As in, I'm visualizing a datalog when I pull it up and look at it. What is the benefit here? Not asking as a skeptic, either. I'd like to use it if it's going to have value to me, a person who is brand new at tuning.
What this does differently:
It finds the stuff you'd miss. It automatically pulls out your WOT passes, flags knock events, catches AFR deviations from target, and shows you where boost dropped off. Things that matter for keeping your engine alive, especially when you're new and don't know exactly what "bad" looks like yet.
It stacks channels on top of each other visually. So instead of scanning columns of numbers trying to correlate "was my knock happening when my coolant temp was high?" you just see it on the chart. RPM, boost, knock, AFR all lined up on the same timeline.
It gives you KPIs up front. Peak boost, max knock retard, AFR spread. The numbers a tuner would pull out manually, you get instantly.
Basically if you're new to tuning, a raw CSV is like reading the matrix. This turns it into something you can actually learn from without years of experience knowing where to look.
