Accuracy/resolution- small pulse injector dutycycle
Old May 1, 2026 | 03:53 PM
Full Power's Avatar
Default Accuracy/resolution- small pulse injector dutycycle
Question of how accurate the fuel calculations/ observed injector duty cycle is at low loads and idle conditions.
Can one MEASURE actual total fuel flow with any accuracy with injector duty cycle at idle or cruise conditions?
Anyone ever attempt direct reading fuel economy MILES per GALLON, derived from injector flow x duty cycle x rpm x (constant) ?
Does small pulse adders, minimum pulse duration get added in the pcm, or are these factors included in displayed Injector duty cycle?
A channel to display, or LOG calculated fuel consumption rate would be pretty cool.
