Help Disabling Rear O2 Sensors
From what I’ve read, older HP Tuners versions supposedly allowed you to disable the rear O2 codes, so I tried going that route, but I ran into another issue the older versions of VCM Suite don’t seem to communicate with the MPVI4 interface.
Has anyone with an MPVI4 found a working solution or workaround for this? Trying to figure out the best way to handle the rear O2/heater circuit codes on the newer software.
