Bosch 868’s
I dug around some more and I think I found the reason you're getting conflicting answers. The Bosch 0280155868 is an older Bosch Design III injector that FAST sold as a 36 lb injector. There is plenty of flow-rate information out there, but very little verified offset, short pulse, and injector characterization data. In fact, I found several forum threads of people looking for the exact same information and not finding a definitive answer.What does seem to be consistent is the flow rate. Most sources list them at roughly 36 lb/hr at 43.5 psi (3 bar), which works out to about 42 lb/hr at 58 psi (4 bar). I also found a Holley discussion on the exact 0280155868 injector that calculated them at about 42.4 lb/hr at 60 psi, which again puts them right around 42 lb/hr at your verified 58 psi fuel pressure.Based on that, I don't think the IFR is wildly wrong if you're already using 42 lb/hr. The bigger issue seems to be that Bosch never published complete characterization data for these injectors, so a lot of people have had to piece together their own offset and short pulse data from various sources. I even found an old Corvette forum discussion where a guy was building his own offset curve because he couldn't find verified data.Since you've already verified static 58 psi returnless pressure and you're only about 3.5% lean at WOT, I'd honestly say you're probably closer than you think. If it were mine, I'd trust the wideband more than random injector tables pulled from old tunes. Unless someone can post a known-good HP Tuners file using 0280155868 injectors, I'd be more inclined to make small adjustments based on actual wideband feedback than keep mixing and matching offset data from different sources.Sources I found:
ThirdGen.org - Need Help Bosch III Injector Data EECTuning.org - Bosch 0280155868 Injector Discussion Holley Forums - Injector Data Bosch 0280155868 CorvetteForum - Injector Offsets for Bosch III 0280155868
