Downloading an Edit file written on a different version?
Old Aug 3, 2004 | 10:46 AM
Camaro ChriSS's Avatar
Default Downloading an Edit file written on a different version?
I have version 1.21 of Edit, which is an older version. If a sponsor (or someone) was to write me up a file using a newer software version, would I be able to download it onto my PCM with my cable module? Or is there an incompatibility issue?
Old Aug 3, 2004 | 11:02 AM
horist's Avatar
shouldn't be a problem, you may not be able to see all of the changes they made (as 1.21 doesn't have as many accessible tables as 1.4) but the write process is the same so shouldn't a problem.
Old Aug 4, 2004 | 09:43 AM
383838's Avatar
Yes, you will be able to write the file, just not be able to edit some of the changes.
