idle and cam
Old Aug 5, 2004 | 08:28 PM
jason5's Avatar
Default idle and cam
can you get rid of the raw gas smell at idle with a 230/230 591/591 cam, or does that just come with the territory, if you can fix it how do you in edit. i have done the ve tables 60/80/90
Old Aug 5, 2004 | 09:14 PM
ram-it's Avatar
What area of the VE table did you do? Hopefully it was 400-1200rpm. You will have some but it should not be that overpowering.
Old Aug 5, 2004 | 09:32 PM
jason5's Avatar
[yeah i did the 400-1200 range, should i go more its bad
Old Aug 5, 2004 | 09:52 PM
ram-it's Avatar
If you do not have any idle problems then I would look else where. You did not mention if this happened when it was a hot start or all the time. I had the smell on hot starts because it was trying to find idle. The VE table cured my woes. Have you tweaked you IFR's?
