Code P0113
Old Aug 8, 2004 | 11:07 PM
onyx's Avatar
14 Second Truck Club
Default Code P0113
its...... IAT High Input ........
what would cause this?... i think we might have swapped the wires when we soldered the wires when we were extending the wires from the stock loom....
we were installing the radix.
Old Aug 9, 2004 | 06:03 PM
L-EATER's Avatar
11 Second Truck Club
I took a quick look through the ol service manual and it looks like the most likely cause is a wiring prob. I would cut out those solder joints and re-do them. The polarity on the wires doesn't matter. The prob is either the wiring (most likely) a bad sensor, or a bad pcm (least likely)
Old Aug 9, 2004 | 07:36 PM
onyx's Avatar
you mean re-solder?.. or cross em back over?... i dont think we used the some gauge as oem.. so maybe that has something to do with it...
