Open headers and o2
Old Aug 11, 2004 | 05:09 PM
HumpinSS's Avatar
Default Open headers and o2
what are the effects will the ever get hot enough to operate closed loop conditions
Old Aug 11, 2004 | 08:55 PM
Magnus's Avatar
LS1TECH Sponsor
The problem is the O2's are too close to the end. Unless you are at WOT, if you are in closed loop the outside air contaminates the O2 readings and your car will continue to add fuel until your LTrims are maxed out.
When I run open headers I force the car into 100% open loop.
Old Aug 11, 2004 | 08:59 PM
HumpinSS's Avatar
That is what i seen but wanted to confirm.
Thanks
Old Aug 11, 2004 | 10:02 PM
SS SLP2's Avatar
think 02s need to be 18-20 inch away from open end or 02s will read cold air coming in
