Nx Maf Kit\codes
Old Aug 18, 2004 | 02:15 PM
ls1pepito's Avatar
Default Nx Maf Kit\codes
I just got a NX MAF kit installed on a 02 Trans Am, used it once, and the car came back with a check engine light, got it checked, and its the front 02 sensors, and the Mass Airflow sensor, got the errors cleared, but how can i fix this so it wont happen again. Dont want to delete the sensors with ls1 edit, trying to find a fix. thanks
Joe
Old Aug 18, 2004 | 02:36 PM
ataylors's Avatar
sounds like it is getting on the MAF sensor. Are you sure you have it on the right side of the sensor?
Old Aug 18, 2004 | 02:56 PM
ls1pepito's Avatar
On the right side? on the right hand side i have the fuel line, and on the left i have nitrous.
Old Aug 18, 2004 | 10:50 PM
ataylors's Avatar
I mean that it is not spraying across the MAF, that it goes after
Old Aug 26, 2004 | 09:56 AM
ls1pepito's Avatar
Checked that, its right, changed out the fuel filter, cause I dynoed to car and it was running lean, bottle has pressure, but when i hit at WOT nothing happens, also have a msd window switch at 3000 close at 6000.
