new stall / transmission
That being said, I've been toying with the shift parameters to try and get it to shift at 1-2, 6600...2-3 6500...3-4 6500 respectively. Only the car insists on shifting around 6300 in all gears at WOT. I'm not sure if the transmission is taking over due to the vacuum modulation and shifting regardless of what the PCM is doing, or if the tune is wrong. (Probably the latter) So...any ideas?
I've got the converter set to not lock until 4th gear just fyi. No misfires, etc.
