Reset PCM after changing collant temp sensor?
Old Aug 26, 2004 | 09:20 AM
BadAndy's Avatar
Default Reset PCM after changing collant temp sensor?
Do I need to reset my PCM after I replace my coolant temp sensor?
Old Aug 26, 2004 | 12:34 PM
deezel's Avatar
I don't think so. Maybe if you had a code for a bad sensor...
Old Aug 26, 2004 | 02:02 PM
BadAndy's Avatar
Intermittent code for coolant temp. Last reading was negative 30 degrees.
Old Aug 26, 2004 | 03:25 PM
deezel's Avatar
The code should go away after a few drive cycles with a properly working sensor installed. It wouldn't hurt to reset the PCM if you want to.
