HELP have ls1 edit installed cam cannot get to idle
Old Aug 26, 2004 | 09:04 PM
krl's Avatar
krl
Default HELP have ls1 edit installed cam cannot get to idle
Installed a 224 228 580 lift on 114+2 lsa in a C5 along with heads and headers
I have ls1 edit and set the idle up to 950 but it just drops past 950 and dies
I drove if 250 miles today and if anything it is worse
Need some advice on what to do
Thanks
Kirby
Old Aug 26, 2004 | 10:25 PM
Slowhawk's Avatar
LS1Tech Sponsor
Have you done the idle relearn yet?It is very important on a C5.
Old Aug 27, 2004 | 02:22 AM
LS1 Swapper's Avatar
Curious how does one do the idle relearn process when the engine won't idle and only runs with help from the throttle peddle? I may have a fuel pressure issue, looking into that but was interested in the idle relearn process when it won't stay running without help.
Old Aug 27, 2004 | 04:45 AM
krl's Avatar
krl
Default idle
Do not know how to do the idle relearn???? It will not idle at all though.
Kirby
Old Aug 27, 2004 | 07:37 AM
wait4me's Avatar
ill fix it and get you going, just email me at jessebubb@yahoo.com.. need specs of your motor
Old Aug 27, 2004 | 07:59 AM
krl's Avatar
krl
Thanks just sent you an email with LS1 edit flash file as well
Kirby
