Copying High Octane table to low table???
Old Sep 1, 2004 | 08:27 PM
TK 14 SS's Avatar
Default Copying High Octane table to low table???
Is it possible to "easily" copy the high table values over to the low table. I want to try to eliminate any KR in order to troubleshoot any other possible factors. It seems to me that I've done this before... or does it have to be done "manually" (typing the proper values into the low table...)?
Troy
Old Sep 1, 2004 | 08:37 PM
2xLS1's Avatar
It's as easy as copy > paste.
Old Sep 1, 2004 | 08:56 PM
TK 14 SS's Avatar
Oh yeah, did I mention that I'm using LS1Edit? 'cuz it doesn't work that way (at least not that I know of yet)
Troy
Old Sep 1, 2004 | 09:21 PM
2xLS1's Avatar
I have edit too. When you open the table, under the edit menu, you have copy, paste, and select all.
Old Sep 1, 2004 | 10:01 PM
TK 14 SS's Avatar
I must be retarded because I don't see (have) that. When I open the table it only gives me the options underneath (i.e. compare to 2nd file, edit whole table, etc...)
I have version 1.1 8/10/2 is that the reason??? their really isn't even an edit tab on the tables and in the program itself the edit tab gives me the Trans cal, Engine cal & System cal, etc...
Old Sep 1, 2004 | 10:30 PM
2xLS1's Avatar
Attached Thumbnails Copying High Octane table to low table???-edit1-small-.jpg
Old Sep 1, 2004 | 10:37 PM
TK 14 SS's Avatar
Oh wow! cool!
But, I don't have that
Thanks for your help and patience
I see the "Have HPTuners Pro, Will Travel - Cheap 98-02 F-Body PCM Edits" Too bad your not a little closer I could sure use a GOOD tuner. I got a pretty much generic tune (from a sponsor to remain un-named) and would love to have somebody actually look into some things and wring this thing out for all it's worth.
Troy
