Engine running hot.... PCM issue maybe????
How can I check to see if my fans are coming on when they're supposed to?
Here's my post in the external section:
What on earth can be making my engine hot?
FACTS:
There is nothing stuck up in front of my radiator
The coolant is totally full
The coolant starts to flow after I let it idle for awhile
The fans are working just fine, they were checked thoroughly
My air dam in front is perfect
Symptoms:
If I drive in the city on a hot day (A/C OFF), the temp will go right up to the 210 mark, which in my engine equals about 230 degrees, according to the scanner.
If I put the air on it will quickly go right past the 210 mark and keep on going if I let it. I have to then put the heat on full blast to get it to come back down.
If I'm on the HWY on a hot day the temp will rise to about 215 degrees(scanner). If I put the A/C "on" it will go up to the 210 mark and maybe a little past.
The engine before rebuild never went above the 155 degree mark no matter where or how I drove it with the A/C OFF. With the A/C ON in the city on a hot day the most it would ever go is about 185 on the gauge. It never once saw the 210 mark.
It seems that when I turn the A/C 'on" all hell breaks loose. Because sometimes it'll stabilize and not climb, but as soon as I turn the A/C "on", BAM!!! The needle moves like a widshield wiper.
Could the thermostat be sticking open?
Can a water pump that does not leak, not pump water properly?
Can a failing bearing on the compressor be dragging my engine down when the A/C is "off", and then just totally killing it when its "on"?
Any ideas? I'm getting pissed now
I'm really not sure how you could of been running at 155* or so as that is even lower than a 160* thermostat. With my 160* thermo i average 180 degrees on the highway. My low fan is set to come on at 184. If I had no fan programming with my converter and a/c on i'd be well up into the 220's. So i'm not sure anything is wrong other than a new thermo and a tune to get the fans on early
Edit: I just read your sig, with that motor
i'm assuming you have every thing done with regards to a thermo and tuning. Sounds like its just to much for the stock radiator
