Cranking A/F ratio
I thought about having a bad sensor. On cold startup the ECT and the IAT are showing what the outside air temp is. The MAP on start-up while the engine is cranking but not started is 97-102 Kpa. There is no MAF frequency until the RPMs are greater than 300 or so. This all seems correct.
John
It's got seconds down the side, and temps across the top.
Engine,
Fuel Control,
PE, Injectors, Cranking, Flood and DFCO,
Then a section on that tab for cranking fuel.
At hot temps, the multiplier is .99
At colder temps the multiplier is high, and becomes higher the longer the engine is cranking.
