Can I look at your trans table?
I lowered the shift rpm to 5000 and the shift mph is at 69mph and it's still doing it. I'm asusming I just use the "normal" tab for tuning the trans since there is no performance button on the z28 thus I shouldn't need that table. And hot shoft is for when temps get high, right?
I can post my .ls1 file if someone wants to look through it, or if you can email me yours assuming you have the same gears and converter setup.
I just don't know where I am going with this...is it shift points causing problem? What about adjusting for converter slip?
Lost here... I need to know asap if it's a tuning issue or a mechanical trans issue.
RPM Tranny Gear ratio 3.059 1.625 1.00 0.696 ==== ==== ==== ==== ==== 700 4.8 9.0 14.7 21.1 800 5.5 10.3 16.8 24.1 900 6.2 11.6 18.9 27.1 1000 6.9 12.9 21.0 30.1 1200 8.2 15.5 25.2 36.1 1500 10.3 19.3 31.4 45.2 2000 13.7 25.8 41.9 60.2 2500 17.1 32.2 52.4 75.3 3000 20.6 38.7 62.9 90.4 3500 24.0 45.1 73.4 105.4 4000 27.4 51.6 83.8 120.5 4500 30.8 58.0 94.3 135.5 5000 34.3 64.5 104.8 150.6 5500 37.7 70.9 115.3 165.6 6000 41.1 77.4 125.8 180.7 6100 41.8 78.7 127.9 183.7 6200 42.5 80.0 130.0 186.7 6300 43.2 81.3 132.1 189.7 6400 43.9 82.6 134.2 192.8 6500 44.5 83.8 136.3 195.8 6600 45.2 85.1 138.3 198.8 6700 45.9 86.4 140.4 201.8 ==== ==== ==== ==== 1st 2nd 3rd 4rd
https://ls1tech.com/forums/pcm-diagnostics-tuning/211850-shifts-early-into-od-can-tuning-fix.html
I also had to go back and reset my tcc points back to stock, because those shouldn't really change.
You need a 200-300 rpm cushion beneath the limiter, when choosing the rpm and mph for the shift. You can always make the mph a little low, and let the rpm be the controlling factor.
