missin driving me wild!!
the car missfires under any load and slightly while idling, ses flashes when cruising (random multiple missfires code).
here's some history of the problem, it started with a single miss every 10 or so minutes apart while in 6th under load. then the misses started getting worse thorough out the day untill it reached the condition above. it almost felt like a broken valvespring ( cause it happened om my car before).
we hooked the car to the scanner and it showed # 5 missfiring , so we change all the plugs to be safe and try again, now 1, 4,5 are missing.
so to keep it short here is what we did:
-swapped plug wires
-used a different coil and moved it to several locations
-did a compression check
- leak down test
- pulled valve covers and checked for broken springs
- pulled pushrods and checked for straightness
all had no result on the miss.
what can it be?
could it be a bad crank positioin sensor? cam sensor?
for some reason i keep thinking it could be that the reluctor wheel on the crank loosened up ( he just put in a new eagle crank), could that be the problem?
is there any way to check that?
