Safe, effective way to raise the idle?
Old Sep 25, 2004 | 02:44 PM
RyanJ's Avatar
SSU Moderator
Default Safe, effective way to raise the idle?
My idle is low enough that I have a pronounced squeak/rattle in the exhaust in gear w/ the A/C on. Without the A/C it is occasional but not too bad. In park its not there. Its totally RPM driven...especially since I have a vig3200 w/ lowered my idle.
Now, the question is how to I raise it free and easy. I have done that idle relearn crap, and played with the idle set screw. If I raise it at all it surges.
So...drill a hole in the TB? What is too big? if I go too big will it affect the car? Will the PCM relearn the low idle on its own?
What else could I do?
Old Sep 25, 2004 | 02:51 PM
slow's Avatar
what is your commanded idle in the computer ?
Ryan
Old Sep 25, 2004 | 04:00 PM
Another_User's Avatar
Adjusting the set screw is the same as drilling the TB blade. Don't drill it. It sounds like you need tuning to fix that.
Old Sep 27, 2004 | 09:04 PM
RyanJ's Avatar
SSU Moderator
I have no autotap...but if I can remember back in the day it would hover in the 660rpm range, is that what you were asking?
Old Sep 27, 2004 | 09:14 PM
slow's Avatar
i was asking what is the comptuer programmed to idle at, auto or M6
sounds like you need tuning.
Ryan
