need help richening my afr
Old Sep 28, 2004 | 01:16 PM
bigMAC's Avatar
Default need help richening my afr
Alright I'm a and I'm running alittle lean. On the ve table, if you multiply the entire table by 1.025 than does that richen or lean out the afr?
Old Sep 28, 2004 | 01:43 PM
luv2spd's Avatar
Increasing ve adds fuel. How are you determining that you're running lean? Most likely you won't scale the whole ve table, just certain parts of it. You could also use the ifr table if you want to scale the whole thing. Multiplying by less than 1 will richen it up because the computer would think that there is smaller injectors so it increases the pulsewidth, which makes you run richer.
Old Sep 28, 2004 | 02:45 PM
bigMAC's Avatar
Thanks. I had my car on a dyno with a wideband and saw I was running lean.
Old Sep 28, 2004 | 04:40 PM
luv2spd's Avatar
Oh, so you're talking about wot afr? If that's the case use the PE table to richen it. Raise the PE values to richen up wot operation.
Old Sep 28, 2004 | 06:22 PM
bigMAC's Avatar
Thank you, same rules apply right? Higher the value, the richer it is?
Old Sep 28, 2004 | 06:25 PM
luv2spd's Avatar
Yep!
