bad try
Old Oct 3, 2004 | 07:23 PM
Q8sLp's Avatar
Default bad try
i just try this maf translator in my car he makes run like a stock ls1 i removet a way i hate it
Old Oct 5, 2004 | 08:10 PM
oOoLy's Avatar
Last night I saw your car and I think you lost some power with this ( maf translator )
Old Oct 5, 2004 | 08:19 PM
Q8sLp's Avatar
i blive it used to nitros cars
Old Oct 5, 2004 | 08:40 PM
MKS's Avatar
MKS
''The MAF Translator unit allows you to richen or lean out your car's fuel mixture up to 14%. It plugs in between your mass air flow sensor and the car's PCM and adjusts the rate of fuel delivery and amount of spark advance to allow you to richen or lean the air-fuel mixture to your specific needs. Installation is simple and each unit comes with detailed instructions. ''
if you take it to the dyno and ajust your a/f ratio with it im sure you'll see some HP gain
