MAF vs. SD tunes, pros and cons.
Sam at Sam's Performance is about the best I've seen with SD tunes. He won't give away tunes, but he knows his stuff. There are a few others that do it, but I haven't seen their work first hand, so I can't speak for their work.
I will say I have seen a 273/273 104LSA 103 ICL cam in a 346 behind an Automatic with a big stall that had plenty of good manners and idled at 850 RPM with an SD tune. I drove the car , and it had plenty of grunt, and ran hard. I also drove a SD tuned car with a 242/242 108/108 cam. Acted like a stock car...
I have seen 0 drawbacks to SD tuning. I expect once more folks understand how it is done, more folks will do it.
Will the A/F go out of sync with SD and temp changes?
I have a TR224 and IMO it doesnt need a SD tune.
Its pulls very hard,has plenty of throttle repsonse and gets great mpg.
Ive heard mention of people disabling LTFT learning and then adjusting VE based on the STFT histogram. How is this accomplished?
Also, whats a good starting point for my PE? I think I have it set for 1.85 across the board. Another question is can my PE TPA% enable stay bumped up for good? Its between 10 and 20% higher than the stock tune to get into PE.
Thanks,
-Tony
Thanks,
-Tony
DOH! I meant 1.185 which is ~12.3. I guess Ill start there and check for KR, and if I dont get any, ill bump it to 1.17. Thanks for al the help HumpinSS and the rest of you guys too! The Best V8 Stories One Small Block at Time
I have not found any car that doens't respond with better throttle response with SD. As for re-tuning, any change in efficency would require looking at the tune. Since most folks doing them right now have tuning software, that isn't an issue. As with most shops, if you get a tune done, re-tunes are free in most cases.
Thanks, -T
Anyway, yeah, I figured why not make use of it while Ive got it so I just cant leave well enough alone. Learning a **** load from all these guys here, so yeah, i'd be happy to spend a day working on a SD tune for you. Besides, you havnt had a ride in my car yet since the headers / TD's / 4.10s. Shes a beast compared to where she was.
Anyway, Swap out those springs yet after the unfortunate mishap? If not, gimme a ring and Ill help you out with them.-T
