MAFT settings
Old Oct 19, 2004 | 05:22 PM
freakynipples69's Avatar
Default MAFT settings
Can anyone tell me what I should set my MAFT at with my mods(check sig) to get the most HP out of everything. I'm not sure what it's set at right, I'll check and post it up later.
edit: Just checked my current settings, both ***** are set at 4
Old Oct 19, 2004 | 06:19 PM
luv2spd's Avatar
You need to use a scan tool to check the changes you've made. Otherwise you'll just be guessing and you could end up going to lean and causing damage. You could also just tune it on the dyno with a wideband 02.
