High idle
if New... what did you do immediately before it did it?
If always... a vacuum leak would cause high idle always
Sounds like your Idle Airflow table is off....
Do you have a scanner? if so log your IAC values...
TB drilled out at all?
edit: just read your last post.... the 8% can be actual or can be a bad TPS sensor....
Here's what I'd do first....
if it's showing 8%... put your laptop in the engine bay w/the hood open (HPT cable is plenty long)
Try to force the TB closed by hand... does it go to 0? if so then your Throttle cable is too tight.... if you have TCS I can explain how to adjust... (follow the throttle cable back and you'll see a fitting that you can adjust) ... i'm not sure on non TCS cars
if you can force the TB all the way closed and it still shows 8% i'd first reset the PCM (I've seen one car that was showing 17% TPS on idle one day... few weeks later it was fine... I don't know why) using the good ole fuse method or discon battery overnight
If that doesn't fix it... see if someone local will let you try their TPS sensor (it uses 2 star bolts I believe... not sure of size) ...
Also.. is your TB ported? if so by whom? and was it your actual TB being ported or did you do it on an exchange basis? (I've seen issues where people getting TBs on exchange basis had probs since the exchange core was from a junk yard car and the sensor was fubared)
edit2: holy fawk... talk about a thread from the dead! lol....
On the way home from classes today it started to hang up at around 1800, then by the time I made it home it was about 1500. I popped the hood and put my hand on the throttle cam and was pushing it shut, but physicly, it was already shut.
