Code P0704......
Old Oct 24, 2004 | 09:58 PM
Joker # 9's Avatar
Default Code P0704......
Says its a Clutch Switch Input Circuit Malfunction....Anyone have any insite on whats going wrong and how to fix it?
Old Oct 24, 2004 | 11:13 PM
monodax's Avatar
It is the sensor that is depressed when you let your clutch out. It basically is for the VCM to know when you press the clutch in for starting the car, etc...
I had to replace my sensor as it went bad. Yours may have come lose or the harness may be lose. You will need to remove the panel under the dash to get to it easily. The sensor is pretty inexpensive I believe mine was 12.00 from the dealer.
