Low coolant light on, but everything is fine?
Old Oct 31, 2004 | 08:53 PM
WAGE_SLAVE's Avatar
Default Low coolant light on, but everything is fine?
Is my sensor bad, I cleaned it. All levels are fine, yet my coolant light is still on
Old Oct 31, 2004 | 09:44 PM
SmokingWS6's Avatar
It's VERY common. After a few years or high milage, just about everybody has experienced the problem. Most live with the light but it bugged me so I cleaned the sensor. I think they are around $24-40 brand new. If the fluid is topped off in the radiator then everything is fine with the motor and it does not affect the PCM in any way.
Old Oct 31, 2004 | 10:16 PM
nonnieselman's Avatar
Default low coolant light
on my 2000 silverado, i get the low coolant light every now and again.and i check it and its just right. i have gotten the check engine oil level a few times when its topped off also?? and not to mention the gas gauge loosing it mind jumping from full to empty with the low fuel light, then it jumps back up?
Old Oct 31, 2004 | 10:44 PM
SmokingWS6's Avatar
I've had the gas guage problem too. Seems the general needs to stop cutting corners on cheap sensors and wiring.
