Will replacing knock sensors do any good?
Is this in Edit Knock Retard / Attack vs RPM? Looks like...
So basically you are telling the PCM to wait 4 seconds before bothering about KR?
Talking about 98's: I had a lot (6-7) of KR at 1400-1600 rpm and 0.4-0.5 G/cyl (85-90 kpa MAP). The only solution was to reduce timing 8-10 degrees in that spot. The PCM did only removed 4-5 degrees but this was enough to get raid of KR (in thaht particular spot). Do you have (had) the same problem?
Reducing the timing did eliminate KR, but the engine still sounds the same at that particular RPM vs MAP (or G/cyl) spot.
I don't know if the LT headers are adding some new noise or what, I just know that if I disable TCC there is no KR at all. No matter which timing I set. With no TCC it's not possible to have low RPM and high MAP, so I'm just avoiding the KR zone. But to disable the TCC can't be the solution
Do you have a M6 or an A4?
