Surging/Bucking...the saga continues...
Old Nov 9, 2004 | 07:33 PM
Another_User's Avatar
Default Surging/Bucking...the saga continues...
I am really starting to get pissed. Reduce timing=surging and bucking. Add timing=a little less bucking. I have fuel...and air...WTF!!! Sometimes it goes away, but then sometimes it comes right back. How much timing is safe to run at 1000-1600 rpms without blowing up my engine? The darn thing seems to like timing at low rpms, but I don't want to give the car too much. I would imagine that it is safe to run extra with a cam because of reversion and lower cylinder pressures. Any comments?
Old Nov 9, 2004 | 07:38 PM
five0killr's Avatar
i like to drive at like 12-1400 in 6th a lot of times and sometimes its smooth, and sometimes it bucks and surges like a bitch...even in the nice cold weather..i had no idea it was a timing issue..i just thought the cam didnt like it too much...on the other hand..wouldnt that create some knock retard?
Old Nov 9, 2004 | 07:42 PM
I don't know, but I have heard that the trucks run more timing at low rpms than we do, and they have tighter lobe seperations stock. I think it is timing related. I have messed with everything else already, so I pulled timing and it got worse. This sucks.
Old Nov 9, 2004 | 09:28 PM
luv2spd's Avatar
I hear ya. I'm working on some surging as well. It's the worst trying to idle around in first gear.
Old Nov 9, 2004 | 09:29 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
You can add timing and fuel (lots of it at low rpm with no issue)
Old Nov 10, 2004 | 02:25 AM
Black02SS's Avatar
I belive I see around 35-39*.
Old Nov 10, 2004 | 04:20 PM
At 1200-1800 rpms? How much timing is too much at light throttle, low rpm?
