Big Stuff 3 ??
Old Nov 19, 2004 | 10:31 AM
OrangeFRC's Avatar
Default Big Stuff 3 ??
Anyone use this on a LS based setup yet ? I am considering it over the FAST for my C5 project.
Any feedback would be great !!
Old Nov 20, 2004 | 01:05 AM
DOC OTIS's Avatar
I am in the same boat. ttt for you
Old Nov 22, 2004 | 04:26 PM
Scooter70's Avatar
I was at Wheel2Wheel last weekend and they had just about every LSx vehicle running BS3. You might try to get Kurt from W2W (forum name: 427) to come in here and explain it for us.
Old Nov 22, 2004 | 04:43 PM
427's Avatar
427
BS3 does offer a stand alone system for the gen 3. It runs on factory sensors. It also has options for running a electronic trans if needed. The base gen 3 system is 2,295.00
Kurt
Old Nov 22, 2004 | 05:06 PM
Bink's Avatar
Kurt the audio opening for your site is great!!!!
Here's a link to the Big Stuff 3 Gen III EMS -> http://www.bigstuff3.com/gen3sefi.pdf
Thoughts?????
Old Nov 22, 2004 | 05:26 PM
gator's 99TA's Avatar
i just ordered a BS3 for my Big Blower LT1 build up. Alan Futral recomended it and upon doing some reseach, it looks to be just the best out there.
Old Nov 22, 2004 | 05:46 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
BS3 is great to work with and is very user friendly!! We are using it on a few cars.
Old Nov 23, 2004 | 07:21 AM
Bink's Avatar
Is this system compatible with fly-by wire used on the C5 Vettes?? Will it piggyback??
Old Nov 23, 2004 | 09:43 AM
OrangeFRC's Avatar
My C5 is no longer "Fly By Wire", and as far as I know there is no stand alone system that is compatible, thats why I switched to F-body style throttle.
Old Nov 23, 2004 | 09:47 AM
JS's Avatar
JS
There working on the fly by system now.
I've also heard there comming out with a complete piggy back system next yr.
Its the best unit on the market...
Old Nov 23, 2004 | 09:48 AM
OrangeFRC's Avatar
Kurt
Thanks for the info Kurt !, I no longer have the electronic trans either, so I dont really need that part.
Does this system use ANY of the factory harness ? or does it come with everything you need to plug and play ? My car has basically "0" factory electronics. Also, one of my major concerns is the data logger, I was going to go with the Accell Gen 7 DFI untill I found out it can only log like 7 paramaters at a time. I would like to see all things recorded more like the FAST setup.
Thanks again !
Old Nov 23, 2004 | 10:00 AM
JS's Avatar
JS
It does that and if your car is being wired standalone u dont need any factory wiring.
Your answer is yes u could install asap
Old Nov 23, 2004 | 10:10 AM
OrangeFRC's Avatar
Awesome, and thanks for the info, guess I need to call Kurt and order one of these bad boys....
Old Nov 23, 2004 | 12:47 PM
JS's Avatar
JS
W2W is the place....
Old Nov 25, 2004 | 08:40 PM
GMC SKI's Avatar
I wanna Keep my factory Gauges working
Have you guys figured out a fix for this i heard there was some talk on keep factory guages
Old Nov 27, 2004 | 09:35 PM
OrangeFRC's Avatar
it was my understanding that this setup works fine with the factory gauges, but in my case I am going all aftermarket so I really can't comment for sure.
Old Nov 28, 2004 | 12:30 AM
Bryan Wilkinson's Avatar
That would be a good move seeing that the Big Stuff 3 and FAST system were all built by the same person, and the Big Stuff 3 is much faster and more advanced.
