ve table for SC
Old Nov 20, 2004 | 11:39 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
Default ve table for SC
i would to see a table for a sc car. i not to fimilar with this so any input is good.is this how you adjust your ltft's?thanks
Old Nov 21, 2004 | 07:59 PM
i guess no one has a sc car. damn
Old Nov 21, 2004 | 08:11 PM
P Mack's Avatar
A car with a stock engine & supercharger would probably have the same ve table as a stock car. The ve of the engine is based on the intake/heads/cam/headers combo because it is MAP referenced. Also, the ve table is only good to 105 kpa so you couldn't use it for boost anyway without some doing a lot of other stuff. Most cars rely on the MAF for fueling under boost because the ve table gets maxed out at 1 bar.
