cam sensor help needed
Old Nov 24, 2004 | 06:35 AM
mkoch1's Avatar
Default cam sensor help needed
I am in the process of installing a tecIII stand alone computer on my 98 ls1 motor and need some help with the cam sensor. the tecIII can use the factory cam sensor if it meets their requirements. Here is what the install manual says. Can any tell me if the stock sensor will work. I talked to electromotive and they just pointed me to the install manual.
"When full sequential fuel operation is desired, a once-per-engine-cycle
synchronization, or “sync,” pulse must be received by the ECU. Typically, the sync pulse is generated by the installation of a 1-notch (or 1-tooth) trigger wheel onto the camshaft. ........
Most types of sensors are compatible with the TEC’s sync pulse requirement.
This would include most Hall effect, flying magnet, and reluctor sensors. As long as the sensor outputs a rising voltage to the TEC3 between 180 and 6 degrees before TDC compression for the number one cylinder, it should work perfectly."
thanks
mark
