Threw code P0161
Old Nov 26, 2004 | 01:48 PM
zchgla's Avatar
Default Threw code P0161
Do i just need to replace the o2's? If so, which ones?
If my 02's are bad, will it hurt the car to run on them?
Old Nov 26, 2004 | 06:42 PM
zchgla's Avatar
Anyone?
Old Nov 27, 2004 | 11:39 AM
zchgla's Avatar
OK, heres the deal. I threw 2 codes, both p0161. What does this mean?
P0161-HO2S Heater Circuit Bank 2 Sensor 2
Old Nov 27, 2004 | 11:51 AM
2001NBMZ28's Avatar
Bank 2, sensor 2 is the passenger side, rear sensor. Look at the sensor wires first. Should be OK to drive since it's a post cat sensor.
Old Nov 27, 2004 | 01:34 PM
zchgla's Avatar
So what would cause it go throw the same code twice?
Old Nov 27, 2004 | 02:24 PM
2001NBMZ28's Avatar
The PCM is just telling you it it's still seeing the same problem after X amount of cycles. You can also try clearing the code/resetting the PCM and see if it returns, but it probably will since it's showing the code twice.
