Need Advice On Ecu!!!!!!
Old Dec 6, 2004 | 09:47 PM
BottleFed383Z's Avatar
Exclamation Need Advice On Ecu!!!!!!
Well, the 383 will be here soon and I need some advice on what to use for the ecu. I was wondering if you guys out there with stroked or heavly worked engines run on a modified stock ecu or a stand alone. Being that I have a 95 Z with a 95 ecu, the technology and speed of the ecu is limited. I have ben looking at lt1 edit but also Paul Williams (the guy building the stroker) said that Fast technologies and Accel DFI 7 are great unit to use. I need something that wont break the bank but also dependable. Plpease, any info or advice that you guys have would be greatly appreciated. Thanks.
Old Dec 7, 2004 | 06:22 AM
GTP40's Avatar
The DFI 7 is worth the $$$. It makes ls1 edit and such look like an etch-a-sketch. Especially if you are planning to run the juice with it, the built-in nitrous controller is second to none. You can't beat adding fuel directly through the injectors.
Old Dec 7, 2004 | 08:04 AM
How much will an Accel DFI 7 run? Can I get a used unit for a reasonable price?
Old Dec 8, 2004 | 06:34 AM
GTP40's Avatar
I think a new setup for an LT1 starts around $1700. Try ebay and you might find something used for cheaper.
