EIO and do I need it?
Old Jan 1, 2005 | 04:23 PM
solobaric's Avatar
Default EIO and do I need it?
Car is in the process of recieving the twin turbo mod Getting ready to order HPT and was just wondering what exactly the EIO upgrade is worth to me and should I get it. I know I could use it to control wideband, but that is about as far as my understanding goes? What else can I use it for?
Old Jan 1, 2005 | 08:43 PM
solobaric's Avatar
to the top
Old Jan 1, 2005 | 09:27 PM
CAT3's Avatar
Restricted User
I am not in the same combo, but same position on HPT. The way I see it, it would be unwise to not get it. Even if the only thing is to log and force wideband mode, its worth it. You can use the wideband feed to go force mode, then use the histogram to modify VE tables! So much easier than dicking around with calculations and formulas and ****.
Good luck.
Old Jan 1, 2005 | 10:27 PM
foff667's Avatar
LS1TECH Sponsor
to to mention you'd be able to monitor an egt sensor or two
