EFILive WideBand Logging Question
Depending on how fast your PC can process the data....the sample rate goes to well over 100 samples per second of the three values. (600 data items per second).
Testing on an 800MHz pentium laptop give about 130 samples per second.
The three values are:
1. Temperature from the cold junction compensated K-type thermocouple input.
2. A/D input 1 (may also be also used for WO2)
3. A/D input 2 (may also be also used for a second WO2)
Probably won't do much good for some wide band O2 cotrollers as they only update their output signal at a slower rate than that.
Regards
Paul
