need help diagnosing misfires
I have switched plug wires around, put in a new set of spark plugs, swapped the #2 and #4 injectors (the easiest to get to), and cleaned the MAF to no avail. The misfires are still showing up on #2 and #7. Is there some common thread that ties those 2 cyls together? I plan on doing a compression test next, but I dont expect to find anything wrong there. It runs fine at all times other than idle-no misfires indicated while driving, just at idle.
What am I overlooking?
If that's the case... it could be a misfire on either 2 or 7 but the PCM wouldn't know maybe?
You've changed plugs, wires, and tried different injectors... only thing left is coil packs
I would put #7 coil pack on #1 and #2 coil pack on #8 and see if hte problem follows the coil packs
That doesn't rule out a valve issue though ... I think a bent valve or bad valve seal could cause a misfire? though if that was the case you'd notice some good oil consumption as well
